So I'm putting together a purpose built Taig lathe for making security pins for lock picking hobby. Z and X will be small direct drive steppers, the spindle will be a 3 phase motor driven by a VFD. I'll need to order two cheap step/dir stepper drivers.
So I need an Ethernet breakout board that supports 0-10v DC out for spindle speed, relay outputs for spindle direction and aux functions. I assume they all have metric butt load of inputs.
I've only used an Acorn before.
