Harmonic Drives
  • Harmonic Drives
    Just ordered a used Japanese made harmonic drive to make a 4th axis for my Taig mill. Shipping from Korea. Couldn't find a 100:1 ratio, got a 50:1. Thinking I will drive it with my all in one servo motor that takes step/dir from the G540.
    Bet you get your harmonic 4th done long before me ! I bought a new harmonic drive off ebay a few years ago, its still in the box. I ended up taking the easy way out, parts out a 9x19 lathe I had that I bought dirt cheap. Used it because it gave me a faceplate, 3 jaw, 4 jaw, MT2 collets and a tailstock. Used a brushless servo with a belt drive. Worked out real nice.
    Still want to do the harmonic someday, nothing matches that approach.
      Thinking about getting a cast iron angle plate as a mount for it. It has angular contact bearings preloaded already so it can directly support the cutting forces.
        I know a guy who lives close to a foundry and had some castings made for his harmonic 4th axis... (uk)
        Someday I will get back to my minimally 3d printed 4th axis...
        sam
          You did your homework much better than I did. The harmonic drive I got does not have its own support bearings. There are quite a few different configurations of harmonic drives. Some I seen even had their own internal servo motor, those are sweet for making a 4th axis.
            sam
            Yes ! That 3d printed 4th axis thread you had on here was extremely interesting ! Hope to see it continued some day.
              I also enjoyed the 3D printed harmonic drive videos.
                Me three as well.
                Keep us posted on the build RB. Building a 4th for the Tormach is creeping up high on my list.
                  MT2? In the spindle? My 8.5x18 has an MT3 spindle as does the 7x10. I use an MT3 to 3C adapter in both with a spin handle draw tube. Well, I hardly use either any more, but...
                    Maybe it is a MT3, been quite a while since I bought the collet set.
                      I'm 99.9% sure it is MT3, the tailstocks are MT2
                        This is one SERIOUSLY nice harmonic drive for 199$. Think I'll start looking for more used parts from Korea!!
ID:	1995827 Click image for larger version
                          What size through hole? I'd love to build a 4th that can take a 1" bar through the spindle.
                            1.024 or 26mm. Keep in mind though that you drive this drive via the inner shaft, so if you bolt to the front, that'll eat up a a lot of room. The next size up is 299$ used. Metal musings on YouTube has a build series of a 4th axis using that one.
                              Thanks, Just looked up his build and he's driving it inline. I want to drive one with a belt, leaving the through spindle for Mill turn style operation. Looks like that bolt circle on the back, while small, should be able to be utilized for a custom pulley to be drive from the side. The price is pretty good too. $250 CDN shipped. A 29mm through hole version is only $285 CDN shipped. Looks like I'm about to be $285 lighter in the wallet pretty soon lol
