FYI-- this marks the first time I've had need to post in the digital machinist section, feels good, like I'm progressing.
In an attempt to bring myself into the 21st century, I recent purchased my first scale(glass)...a vevor 10"
I am building the interface for it myself (seemed like a fun project). Documentation is scarce (that link is all I have).
I had no difficulty picking up the two primary signals (A &B)--digital pulses half a cycle out of phase. There should also be a "home sign", sometimes called "z" or "r1". From a pic I have, it should be just a single pulse, 1/4 cycle length (no pattern or anything). I have meticulously scanned up & down this thing in every way I can: dmm, micro controller interrupt, analog polling & a scope. All of which work to read the primary encoder signals. What i do have is, on the pin that is suppose to be the home signal, is a very low, constant voltage(0.190vdc). Constant is not quite right, as there is about a 30 mVDC variation in that line, which comes only with movement of the scale (at rest it is dead constant).
am I doing something wrong? did I get a bad scale? was a home signal every actually built into the thing? (the sensor head is potted, so I can't peak under the skirt)
so anyone who has one of this scales: does your home signal work? ie after power loss, are you able to move your scale to find absolute 0 ?
at this point, I've exhausted all my testing options, I have an email into the manufacturer & I'm all ears to any suggestions y'all might have. Thanks for your time.
