I think your on the money on PIKA, when the PIKA relay is engaged a little 4v hf waveform is injected between each pair of contacts. I can't see it, only a mess of sub harmonics so I guess my old tektronic d66 scope can't go high enough, but its there and clears that up thanks. I would guess the pair common'd at the relay should be on the - or earth side of the equation so it doesn't short out the contact block when its injecting the signal.
I also see a pulse between the edm cables, 80v if Im reading my dials correctly but not going the direction I would expect and I can't alter the waveform shape by playing with cutting conditions. I must have them shorting out for that pulse not to be making it to the wire. More sketching.
I have been playing round with the cutting conditions (with the wire not being spooled and a little tape to keep the break sensor from activating
) and it has the same sort of things. Sodick supply a big manual of what to enter in there for each type of material and thickness etc, which also of course I don't have.
I'll be happy to get it to make a spark and break the wire right now. But positive steps. A brew to thaw then back at it...
