On my recently CNC'd lathe I was trying out the OD Groove wizard in Mach3. As the cut began with the tool moving forward in the X axis the motor stalled and I hit the emergency stop on the controller.
Now the X axis motor will not respond to Mach3 nor will the keyboard jogging keys make the motor respond. The Z axis motor behaves normally. When I try and run a program the readout in Mach3 on the screen for the X axis changes but the motor does not turn. There is power getting to the X axis motor as it locks up when the controller is on, but I can hand turn it when the power is off. The Z axis motor responds to the program running in Mach3 and to keyboard jogging. I get no error messages on the screen.
Did I fry the stepper or ? All suggestions appreciated.
