Mach3 as DRO
  • #16
    Mach3 does not close the loop but "closing the loop" refers to using the encoder inputs for CNC control in real time, Mach3 can take encoder input and display it on DROs, you would need a Break Out Board and compatible encoders.
    - Nick
    If you benefit from the Dunning-Kruger Effect you may not even know it ;-)
    • #17
      Hi Nick
      I have a C10 Break out board
      http://www.cnc4pc.com/Store/osc/prod...products_id=45
      The encoders are quadrature encoded glass scales. The Mach III stuff is on hold, as I have the Yuri bluetooth DRO to android project working. I have a number of projects that have eclipsed the Mach III dro stuff for a while.
      Thanks
      paul
      paul
      ARS W9PCS
      Esto Vigilans
      Remember, just because you can doesn't mean you should...
      but you may have to
