Hey all.
I have been machining some molds recently that take a fair while, and noticed one or two minor inconsistancies. I did load up the tool once or twice but not enough to loose steps i figure. All in all the finish is great but it made me wonder.
I know very little about steppers and 1/2 1/4 and full step.
I've done some reading, and note that you can pull more torque in full step then 1/2 and it's a significant amount. I would prefer, I think, to go slower, and have more torque, then move fast and potentially miss a step here or there. Is there any way to tell what you running by looking at the board?
Is it true that by adjusting to full or 1/2 step you can pull more torque.
Do you loose noticable resolution?
I think i'm currently running 200 or 300 is steps per in mach3, I will have to double check, but is this worth while, or should I just slow down my feed and slow my accelleration down to avoid missing a step here or there?
Any tips/ hints.
Thanks all.
Any tips/ hints.
Thanks all.
