Homemade Mini Lathe Aluminium Alloy with Slide CNC Linear Ball Bearing Motion Bearing
Parts and Tools:
Wood MDF 200 mm x 650 mm x 20 mm
2pcs SCS10UU 20 mm Linear Ball Bearing Motion Bearing CNC
2pcs 500 mm 20 mm Linear Rails
1 Pcs 530 mm x 140 mm x 12 mm Aluminium Alloy 6061
2 Pcs 60 mm x 140 mm x 12 mm Aluminium Alloy 6061
2 Pcs 80 mm x 120 mm x 12 mm Aluminium Alloy 6061
1 Pcs 80 mm x 140 mm x 12 mm Aluminium Alloy 6061
1 Pcs 80 mm x 110 mm x 62 mm Aluminium Alloy 6061
1 Pcs 12 mm x 140 mm x 12 mm Aluminium Alloy 6061
Lathe Chuck 80 mm 2 pcs, Head Chuk Drill,
More Step by Step and More Homemade Lathe DIY Mill Miling CNC Router here:
More Homemade Mini Press Drill Convert Your Dremel Into A Mini Mill here:
Parts and Tools:
