Homemade Mini Press Drill Convert Your Ozito Dremel Into A Mini Mill
Materials and Tools:
1 pcs SCS10UU 25 mm Linear Ball Bearing Motion Bearing CNC
1pcs 220 mm 25 mm Linear Rails
1pcs 200 mm 20 mm Linear Rails
1 Pcs 250 mm x 60 mm x 12 mm Aluminium Alloy 6061
1 Pcs 80 mm x 100 mm x 16 mm Aluminium Alloy 6061
2 pcs Bearing 40 mm / 17 mm, Lathe Chuck 80 mm, Head Chuk Drill, Motor from Old Hand Drill
1 pcs Aluminium Alloy Profile 300 mm x 80 mm
Homemade,DIY,Lathe,CNC,Milling
More Step by Step and More Homemade Lathe DIY Mill Miling CNC Router here:
More Homemade Mini Press Drill Convert Your Dremel Into A Mini Mill here:
