VFD convertor Huanyang Hy02d223b frequence convertor.
We have a VFD convertor Huanyang hy02d223b frequence convertor, and we obtain the problem that we can drive a motot of 2,2 Kw 1750 Rpm, but no pmower is driving the motor, i.e. the motor runs untill a well defined lower frquence, but above that frequence the motor does’nt turn anymore, although we hear in the motor that the frequence ( sound in motor ) amounts in function of the pot meter setting.
We thing it has something to do with the parameter setting in the convertor, but did’nt find the solution untill now.
Has anybody some idea about the reason of this problem ?
Spec’s VFD : Model Hy02d223B Motor 3 X 220 v 50 Hz 2700 T/min Power 1,5 Kw.
