Where can I find long 5mm bolt?
  • Where can I find long 5mm bolt?
    I need "4", long 5mm bolts in order to mount an "under the counter", radio. It came with bolts too short for my needs. The bolts will have to be around 4 inches long, which I believe to be around 100mm.
    Anyone know where I can buy 4 bolts like this? I only need 4. Thanks
    i usally get mine from the 5mm bolt store.
    you can find it right between the 4mm and 6mm stores.
    is your radio threaded?
    exactly what is the problem other than being "short"?
    more info would be helpful as im a little "short" today on my telepathic skills...jim
    ...jim
      Mc-Master Carr has 5mm x100mm SHCS (Socket Head Cap Screws) availaible. Only in packages of 25 though.
      http://www.mcmaster.com
        Perhaps some threaded rod and 4 nuts would be a cheap solution.
          Get 4, 4", 1/4" bolts, turn them down and thread them in your lathe.
          THAT OLD GANG 'O MINE
            Lee Valley has hardened gutter screws with T20 torx heads - or use #10 or #12 hardware - close enough and plenty strong for a radio (unless it weighs 200lbs.)
              My cabinet is thick, so the 3 inch bolts won't work. I'll need another inch.
                Anyone know of any shops that might ship someone like myself 4 bolts like what I need?
                  you can get them from Dayton supply and tool in Dayton, Ohio. They sell in small qty. but will have to pay shipping.
                    Hi Bobbob,
                    I was looking at the chart as to size of the 5 mm and the next size is # 8. This is only about .002" larger. A # 6 is .204". This is only .007" over. I would think that that you could find something at most fastner supplies. I know some of them have a minimum ticket, maybe you can find a seller that will help you out.
                    How about cutting the ones you have into and welding or soldering a piece of say 1/8 brass or stainless welding rod in the center.
                    Just a couple thoughts.
                    Hope it helps.
                    Good luck.
                    skeeter
                      Threaded rod and nuts- cut rod to length, use threadlocker to secure the nuts on as boltheads.
                        A good source for long thin bolts are old electric motors. Used to keep the front a rear covers together.
                        Matt
                        Matt
