RPC Electical problem
  • RPC Electical problem
    Ok I am going to cover what I have. Most of you probably remember what I have but...
    Lathe: 2 speed motor 3phase 3hp and 1.5hp
    Phase-A-Matic phase converter (no run caps)
    Idler Motor: 5ph 3phase
    My problem. When I try running my lathe in the "High Speed" setting, it either flips the fuse or it has cause another fuse for a different part of the house to flip. I tried running the lathe at the lowest RPM (81) of the "high speed" setting and that is when it flipped a fuse for another part of the house but not the lathe. It does NOT cause any troubles when the lathe is run in its "low speed" setting.
    My fuse is a 30amps at the box for the lathe which is running 220 directly to the lathe with nothing in between.
    What am I missing?
    Thank you all for you help in the past and for the future!!
    What size wiring from the fuse panel to the convertor?
    Also, I have had problems with fuses and rotary convertors. Mine will blow a 30amp fuse just by switching the convertor in.
    The entire circuit is protected by a 50amp breaker and my wire is #6.
    I have even used slow blow fuses still no good. I dont have any shorts, it may just be an inrush from the caps (for mine). JRouche
      I ran 8 or 10ga.
      I had a problem with the fuse popping when I flipped the switch too, till I started spinning the idler motor before i flipped the power swithed. That solved that problem.
      I used slow to blow buss fuses also, but replaced the start box with a 60amp switch box with no fuses. If I didnt get my idler motor spinning fast enough before I flipped the power switch, it would blow the slow fuse. Was tired of spending a buck a fuse.
        CM,
        are you saying you are starting the 5HP motor with start caps and then run it with no run caps? if so, this could cause a current and voltage imbalance that could definitely blow fuses. i start my 5HP idler, and then fire up the 5HP motor on the shaper (and everything "grunts" for a few seconds) and i have never blown one of my 20A fuses. i think all my wiring is 8 ga.
        andy b.
          Andy,
          I dont have run caps. Peter on the the PM website said run caps should fix the problem.
          I will be ordering some and figuering out where to put them.
            Cuemnaker, if your blowing fuses on a branch circuit that your lathe is not connected to you have another serious problem. I would call an electrician to trace all your circuits. Uncrichie
