The bed of the Logan has some dings and scrapes froma knuckle-dragging P.O. I have meant to do something about them, other than stoning doen the high spots.
So I finally found a "round tuit", while poking around the basement trying to avoid some other cleanup work.
I cleaned the offending spots with solvent until there was no hint of any dirt coming up. Then, not having any of the filled epoxy I was planning to use, I mixed up some regular (filled would work better, but could be pricey).
The spots were pasted over, taking no care to get the surface level. I rapidly found out that trying to get the spots filled exactly level was a non-starter.
After the epoxy had cured, I went back with a "burr file" (which knocks off high spots, but glides over smooth surfaces without cutting). The epoxy was actually pretty easy to cut off, and the surface is nice. I
I'd post a pic, but it is clear epoxy, and you can't see it! But a thumbnail glides over, same as the carriage.
It actually isn't difficult....I seem to recall someone asking about it on here...could have been the email group though....
