Beaver Mill spindle runout question???
  • Beaver Mill spindle runout question???
    Friend just bought a Beaver Milling Machine model VBRP ,here's a link with info:
    http://www.lathes.co.uk/beaver/page3.html
    Got it set up in his shop and noticed excessive runout when small hole drilling. There was a ER-40 collet chuck mounted in the 40-taper spindle, so I first indicated the inside of the collet chuck - 0.052" TIR. So maybe the collet chuck is bad? Pulled it out and indicated the inside of the 40-taper - 0.0075" at the bottom, 0.0051" at the top (narrow) part of the taper. Preload, maybe? Pulled the spindle/quill assembly and there was almost no preload. Cleaned and relubed the bearings, preloaded til it felt about right (no instruction manual-please tell me if you know the spec) and assembled. Now indicates 0.0035"TIR, which is still 0.003" too much.
    The inner surface of the 40-taper looks unusual, sort of blotchy, not uniformly shiny. Maybe it needs finish reaming. Maybe new bearings. I'm out of ideas, so let's hear from you...
    Barry Milton
    Barry Milton
    Come on, readers, someone has to have a suggestion...all input is welcome.
    Barry Milton
      The blotcy look is called "frittering" it is caused by never cleaning the socket or shank. It also happens to ER collet and is a form of wear common at extreme speeds - also caused by poor contact of the collet to collet shank.
      Spinle Mate has special stones in their taper cleaner (an aluminum taper e cone on a handle with sprial blades on the cone surface. Anyone with NT spindles should have these - thay can prevetn tool damage and wear of the spindle - they should be used EVERY time a shank is inserted in the spindle (this of cousre is not possible with an ATC, but should be a part of daily care of the machine).
      If the Spindle-Mate can't clear the excess runout up, the shank may need to be reground.
      They make the Spindle-Mates in MT, Jarmo, B&S, NT, and ER tapers (and probably others).
        Thrud,
        Appreciate the help. I've seen those in the catalogs, but never had because my mill is R-8.
        You mention regrinding the taper might be needed. Would a finishing reamer not work?
        Barry Milton
