My own bulletin board
  • My own bulletin board
    http://www.bbssystem.com/index.php?c=2
    I'm thinking this one will be a big hit
    Thanks to our own Three Phase Lightbulb I am moderator of my own BB!
    I hate to say it but MY bulletin board will probably be SO POPULAR that it will devour all his bandwidth in short order...
    Hoffman in Warner Robins Ga
    Techno-Anarchist
    Your a perfect example why the Chaos theory works so well
    -3Ph
      I'm sort of familiar with chaos theory but could you elaborate?
      Techno-Anarchist
        <font face="Verdana, Arial" size="2">Originally posted by hoffman:
        </font>
        "Just a small change in the initial conditions can drastically change the long-term behavior of a system."
        I'm seeing the rippling effects from your forum already
        -3Ph
          "I'm sort of familiar with chaos theory but could you elaborate?"
          It means you can start more touble with the tip of your pinky than a category 4 hurricane can cause for Florida.
            Chaos theory: If you sneeze outside, you might kill 100,000 people several years later due to a hurricane that initially was born from the air pressure delta you generated from your sneeze.
            Or just as likely, you might save 100,000 from preventing a hurricane..
            -3Ph
              Chaos theory? When I took the French girl who knew very little english to the 1% biker bar.
              In about ten minutes she was telling the local club how I could kick ten of thier asses at once. *she saw me take trophies in a tournament.. HA.. Little does that have to do with "real" life. (80's history) No judges to stop for points.. (ha ha..)
              Major Chaos. I was wondering how long I would be in intensive care. I pulled names outa my hat that were ancient. What got me off the hook was when I offered to sell her to one of the guys for $5k..
              On the way home, I split lanes, She peed on my back.
              So, French girls are at the top of the chaos theoryem.
                Material for the "Wrench heads gone wild" forum
                "We'll build any engine...just $49.95"
                [This message has been edited by wierdscience (edited 02-24-2005).]
                  Hoffman has his own BB, the world is ending.RUN! Hoffman, I don't like skydiving the rest is ok.
                  Charlie
                  Don\'t ask me to do a dam thing, I\'m retired.
                  http://home.earthlink.net/~kcprecision/
                    Wierd.....
                    That bloke on the left has his eyeshade on crooked.
                    Allan
                      Can we assume that this BBS will be the new source of tool porn?
                        <font face="Verdana, Arial" size="2">Originally posted by jackb:
                        Can we assume that this BBS will be the new source of tool porn? </font>
                        Tool porn is perfectly acceptable...
                        You can post and talk about anything on my BBS as long as you don't personally attack anyone or post vulgar images or post illegal information, etc. You can personally attack me , but that's it! I won't tolerate personal attacks on others or vulgar images..
                        -3Ph
                          Ive always been suspicious of anyone who jumps
                          out of a perfectly good airplane.
                          ...lew...
                          (sayeth)
                          charlie coghill
                          Charlie
                            <font face="Verdana, Arial" size="2">Originally posted by Lew Hartswick:
                            ...lew...
                            (sayeth)
                            charlie coghill
                            Charlie
                            </font>
                            Who says we jump out of good airplanes? I have two perfectly good gliders on my back so... Why ride in a stuffy airplane, when you can get out, fly around for awhile, then ride your own high performance glider to the ground..
                            -3Ph
                              3PH when I fall I want to close to the ground.
                              Charlie
