Splines
  • Splines
    Howdy from Montana
    Hey does anyone know of a good book on splines, My friend at the local machine/welding shop has a farm fix it job and may have to build a new shaft if the weld up and turn method doesn't work. Info needed most is identification and cutting methods.
    As always help will be greatly appreciated.
    Roger from Montana
    Roger Chevalier
    Dutton,Montana
    I've got a great book on gears and splines from the Barber Coleman Company published about 1950 that has data on everything with the exception of metric for some strange reason Unfortunately it is at work and I can't get it till Monday
      Roger,
      Here you go mate.
      http://www.omnigearandmachine.com/te...nformation.htm
      John S.
        Wow John thats quite a complete referance.
