Fairbanks Eclipse Engine
  • Fairbanks Eclipse Engine
    I finally got this completed enough to get it running. I have been working at it for about six or seven years off and on. It is running in the photo, the digital camera is faster than I realized.
    Jim H.
    Well, JC, I would say that it was time well spent as this is a very good looking job. Wish I was capable of doing similar work.
      Great looking engine. Was it a kit? If so,
      is it still available?
      neonman
        Ooh Ooh I want one too! Is the kit still available?
          I know what you mean about digitals. I shoot some pics of a machining operation with a multi blade insert cutter awhile back and all of the shots showed the cutter and the CHIPS frozen. And this was an old floppy camera
            .........Do it again with shop lighting and no flash. That oughta get you some blur :-)
            Best,
            Rick
            Son of the silver stream ..... Bullet caster.
              It's the flash that stops the action. Electronic flash has a flash duration of about 1/10000 of a second (much faster than a shutter). Put the camera on a tripod or resting on a table, turn the flash off and use the self-timer to trip the shutter since most digital cameras don't have a cable release socket for the shutter. If you push the shutter button, you will probably get a blurry image.
              Nice work on the engine!
                Thanks for the kind words. It is a relatively easy model to build, and good castings. I think there was a build article in Gas Engine Magazine a while back.
                Castings are available from Tom Ball, T&S Model Engine Works. 419-693-6251 [email protected]
                The original carburetor castings did not work too well, and modifications were needed, I picked up on it at the NAMES show, but ask Tom if upgrade is in the plans or a different casting has been made.
                I do recommend it. I have no connection with T&S, but I do know them.
                I got it about 90% completed, and it has been languishing on the shelf for several years. In the Fall, I picked up for cheap a set of castings for a 1/2 scale John Deere. I have forced myself to complete some of the projects lying around here before I embark on that. This is the last. As soon as I get the governor working, I start on the JD.
                Jim H.
                  Good job! Congratulations.
                  A friend of mine build an Eclipse like yours, but a core must have been poorly located in one of the castings.
                  Did you have any problems machining into a cored cavity? That's what has had me holding off getting a set.
                  Orrin
                  So many projects. So little time.
                    Orrin, I had no problems with core shift. If your friend had a problem, did he contact Tom? I am sure he will make good on any casting problems.
                    Jim H.
                      JC
                      What diameter are the flywheels? They might be to big for my machine.
                      Thanks
                      Caddy
                        The flywheels are 7" diameter. The model is 12" high.
                        If you want something smaller, this is the Breisch Little Brother. I built this in the time the Fairbanks was sitting on the shelf. It is about 1/4 scale, 4" flywheels.
                        Jim H.
                          JC, you are one talented bloke!!
                            JC:
                            Thanks for the info. Cool looking little engine. BTW I'm starting on the new (#2) crakshaft tomorrow!
