Fairbanks Eclipse Engine
  • caddy
    JC:
    Thanks for the info. Cool looking little engine. BTW I'm starting on the new (#2) crakshaft tomorrow!
  • Al Messer
    JC, you are one talented bloke!!
  • JCHannum
    The flywheels are 7" diameter. The model is 12" high.
    If you want something smaller, this is the Breisch Little Brother. I built this in the time the Fairbanks was sitting on the shelf. It is about 1/4 scale, 4" flywheels.
  • caddy
    JC
    What diameter are the flywheels? They might be to big for my machine.
    Thanks
    Caddy
  • JCHannum
    Orrin, I had no problems with core shift. If your friend had a problem, did he contact Tom? I am sure he will make good on any casting problems.
  • Orrin
    Good job! Congratulations.
    A friend of mine build an Eclipse like yours, but a core must have been poorly located in one of the castings.
    Did you have any problems machining into a cored cavity? That's what has had me holding off getting a set.
    Orrin
  • JCHannum
    Thanks for the kind words. It is a relatively easy model to build, and good castings. I think there was a build article in Gas Engine Magazine a while back.
    Castings are available from Tom Ball, T&S Model Engine Works. 419-693-6251 [email protected]
    The original carburetor castings did not work too well, and modifications were needed, I picked up on it at the NAMES show, but ask Tom if upgrade is in the plans or a different casting has been made.
    I do recommend it. I have no connection with T&S, but I do know them.
    I got it about 90% completed, and it has been languishing on the shelf for several years. In the Fall, I picked up for cheap a set of castings for a 1/2 scale John Deere. I have forced myself to complete some of the projects lying around here before I embark on that. This is the last. As soon as I get the governor working, I start on the JD.
  • ricksplace
    It's the flash that stops the action. Electronic flash has a flash duration of about 1/10000 of a second (much faster than a shutter). Put the camera on a tripod or resting on a table, turn the flash off and use the self-timer to trip the shutter since most digital cameras don't have a cable release socket for the shutter. If you push the shutter button, you will probably get a blurry image.
    Nice work on the engine!
  • Buckshot
    .........Do it again with shop lighting and no flash. That oughta get you some blur :-)
    Best,
    Rick
  • Spin Doctor
    I know what you mean about digitals. I shoot some pics of a machining operation with a multi blade insert cutter awhile back and all of the shots showed the cutter and the CHIPS frozen. And this was an old floppy camera
  • caddy
    Ooh Ooh I want one too! Is the kit still available?
  • neonman
    Great looking engine. Was it a kit? If so,
    is it still available?
    neonman
  • Al Messer
    Well, JC, I would say that it was time well spent as this is a very good looking job. Wish I was capable of doing similar work.
  • JCHannum
    started a topic Fairbanks Eclipse Engine
    I finally got this completed enough to get it running. I have been working at it for about six or seven years off and on. It is running in the photo, the digital camera is faster than I realized.
