OK, here it is. last evening, teaching my night class on milling, a very disturbing trend occurs. Trammed the head on my mills, checked vise squareness, and solid jaw perpendicular to spindle on my bridgeports. I have to hold .002 over 2 inches.
Darned if I can't hold perpendicular on the parts!!! Or paralllel betwen top and bottom surfaces. i am using the first milled surface as my 2nd and third surface reference off the soild jaw. doing it all right.....this is new.
the flex is at the top of the jaw, and indicating on the back side of the entire solid jaw assy (behind the vise where you do not clamp, the column side), it shows flex of 1/2 the front ammt.
jaws are tight. soild jaw to vise base is quite tight.
I check spindle to vise jaw perpendicular with a 1x2x3 block clamped in the jaws. However, something is amiss......
Bottom line, the entire solid jaw on more than one vise is flexing .0015 to .003. I have six bridgeports, using fair quality vises, a Bridgeport whole cast vise, and a kurt 5 inch.
Tonight, went in and tightened screws holding the soild jaw to the base. Got four to .001 or better with moderate clamping pressure.
Using a brass rod on the movable jaw to hold the part in, but does not matter, does this anywy, even face to face clamped.
It is the .002 issue that is killing me. .005 over 2 inches has never been a problem, and even .002 in the past was a football field.
Looking for ideas, and questions. probably questions at this point so I may describe the issue better to your understanding as you might see to ask
Is this a common occurance?
