Drill chuck arbor taper question?
  • Drill chuck arbor taper question?
    I want to buy a new keyless chuck for my mill. The present arbor is a 6JT(R-8). For some reason the chucks for this arbor are really expensive. Is there a reason for this or is it just because there aren't many around and the supply and demand thing? I was thinking of just buying a new arbor but I'm not sure which taper to buy. Any advice is appreciated. Thanks!
    Russ
    JT6 is the largest taper, and the chucks will be the most expensive.
    For the most part, the chuck selected will determine the taper mount. Get a chuck in the size/price range you want and then get an arbor to fit it.
    Jim H.
      Russ,
      Many people feel that Albrecht makes the nicest keyless chuck & they are available with an integral R-8 shank (Classic Plus model CP130-R8, or model CPD130-R8 with diamond impregnated jaws for holding solid carbide drills).
      I found a new-in-box Jacobs keyless High Torque on eBay (model 130-J6) and bought the R-8 to JT6 arbor. Made in Spain. Incredibly accurate at 0.0009" TIR.
      Barry Milton
        I could be wrong but isnt a jt5 the largest and 6 is down around the jt33?
        but anyway if you have a BP clone I hope you have a riser ring as a keyless chuck is longer than a normal one this makes drilling a pain in the back.
        [This message has been edited by IOWOLF (edited 03-11-2005).]
          <font face="Verdana, Arial" size="2">Originally posted by IOWOLF:
          </font>
          That's right, I replied too quickly, the JT5 is largest, JT6 & JT33 are between the JT2 & JT3. There is also a JT2A, which is a short taper.
          Jim H.
            Damn I'm good!
              Thanks guys! That's what I wanted to know. It is weird though...some chuck mfg in my catalogs still want tmore for a 6JT than for some bigger arbour size chucks. Thanks!
              Russ
