Lathe spindle.. L00?
  • Lathe spindle.. L00?
    My 1951 Leblond is supposed to be a L00, I have several back plates, one chuck.
    The spindle has a female threaded collar on it, chuck has a male w.cone type taper.
    How do you tell one from another is there a spec online anywhere? Where I can confirm what I have?
    I have been shopping online for a 4jaw chuck. Missed out on one Namebrand w/mount cause I forgot about it. It sold for 99$
    David Cofer, Of:
    Tunnel Hill, North Georgia
    Here's a link that might help
    http://shopswarf.orcon.net.nz/chuckmt.html
      Dave,I have a delta 14 with L00 the large dia. is 2.75. it is a slick setup once you get used to it, I have a jacobs collet chuck set ,3 and 4 jaw.
        MSC has a Bison 8" 4 jaw with integral mount for about $290 in the L00. It's a little expensive but I have one and it's really good quality, Bobby
          Thanks..
          I'll print out the "lathe specs" page and add it to my documentation. Three: thank you very much..
          I am not sure I'll go which way with a chuck. I shop ebay for bargains. It took about 30-some odd tries to get some bargains on Jacobs ball bearing chucks for my lathe tailstock and one for my mill.
          I am stubborn, as you might have guessed. The hammer will finally hit the right brand/right one for my machine.
          David
            David,
            Here are a couple more that I was trying to find and finally found them.
            http://www.workholding.com/BISON-SPI...-L-THD-DIN.htm
            http://www.workholding.com/BISON-SPI...2-D1-SPECS.htm
            They show a couple more of different type mounts if you ever run into them.
              Hey David
              http://cgi.ebay.com/ws/eBayISAPI.dll...880997955&rd=1
                Just gotta be careful about those pesky chips inside the L-00 socket...it affects the chuck registration.
                I also got the Bison 4-jaw 10" with integral mount...pretty nice setup.
                  ..........I'm at work, info is at home, but I believe Enco has L00 Bison chucks on sale. I reall an 8" 4 jaw was $239 and no shipping wit da code.
                  Rick
                  Son of the silver stream ..... Bullet caster.
