fixing a slipping keyless drill chuck
  • fixing a slipping keyless drill chuck
    Hello,
    I'm a wanabee machinist who has a mill
    drill and an imported keyless drill chuck
    that after a while doesn't hold the bit
    any more. Short of buying a better drill
    chuck, is there anything that can be done?
    Regards,
    Pat Young
    Pat,
    It's unlikely that you'll be able to buy replacement jaws for an import chuck unless it's a "brand name". MSC sells the Accupro brand (I have not used it) that is pretty low priced & has replaceable parts: http://www1.mscdirect.com/CGI/NNPDFF?PMPAGE=1596
    Albrecht & Jacobs chucks are often listed on eBay.
    Barry Milton
      What ever you do dont buy the thread mounted hand tite keyless chuck. The second down on the left. It may be a Jacobs but they really let the side down on those. They come out on many electric hand drills and are the biggest POS out. I think the discription hand tite refers to there gripping force on the drill not the mentod of tightening.
      That said there are good keyless chucks out there. If you can't afford a quality keyless chuck get a good keyed one.
      John.
      [This message has been edited by zl1byz (edited 03-17-2005).]
        I have a keyless chuck on a Bosch drill and it was acting up. I pointed it at the ground and shoved a needle air compressor up into and blew the hell out of it. Then did the same thing with WD40 and blew it out again. I light coat of 3 in 1 oil and it works great again. Don't know if this would work for you.
