in a pinch maybe you can double-nut a bolt and use a socket or wrench.....not sure if you're just "jammed up" there with a one-off or NEED the proper tool....good luck
Chris
If when you find a source it is worth more to purchase than it is to you. Consider if you have the time, ability and already have 3/4 or 1" sockets. Make up a peice of hex out of some good steel and just use a 32mm socket to drive it.
