Back again guy's.
Does any one resharpen or recycle those expensive DAMN inserts for mill's and lathes?
Also
Can you resharpen the cemented type tool bits.
Yes I am aware of the carbide grinding wheels but what grit to use?
My surface does not appear like the factory surface. I believe I have 50 and 100 grit wheels.
Can you reshape the tool bit?
How does one go about reshaping the steel underneath the carbide?
Can you use the carbide grinding wheel to do both the cemented carbide and the steel below it?
What grit?
Thanks again.
JRW
Also
What grit?
Thanks again.
JRW
