Photo: Bellanca Aircraft Shop Circa 1930
  • Photo: Bellanca Aircraft Shop Circa 1930
    THAT OLD GANG 'O MINE
    What is that string that seems to be running everywhere??
    Rob
      I would guess it is an open day or sale at that place and the string stops people going places the owners don't want them to go....I see it at auctions all the time...
      Great picture...
      Precision takes time.
        Notice the power hammer mounted on the side of the column going up to the roof? Nice!
        cheers,
        Michael
          <font face="Verdana, Arial" size="2">Originally posted by Michael Moore:
          cheers,
          Michael
          </font>
          Plannisher
          The strings layout the course for the Grand prix races later that day
            The strings are for the tin can phones!
            Ed Pacenka
              I suppose that could be just a planisher, but it sure looks a lot like a Pettingell or Yoder power hammer for the upper mechanism and the lower anvil.
              cheers,
              Michael
                Yep,Plannisher?Planisher?(seen it spelled both ways)
                Reason I know is we had one twice that size at work.
                Same identical construction,but free standing through the aid of an H-beam column and heavy fabricted base.
                Ours was newer,a ball bearing unit with a v-belt drive.
                It had a 3/16" mild steel capacity,we used it for the odd job,but later took it out of service,it made enough noise to raise the dead.
                It sat around for ten years or better and we finally sold it for $300 as I remember.
                I care nothing for a plannisher,but a power hammer I would starve for
                  i was wondering what that thing on the column was. so it's a planisher.
                  how about the tiny horizontal mill next to it. i'd give my eye teeth for one of those little cuties.
                  andy b.
                    How about that stiff arm drillpress on the opposite side of the column?
                    Ahhh...what the old machines we see today looked like new and un-fornicated
                    Oooh...oooh! Foot shear behind the planisher!
                    [This message has been edited by wierdscience (edited 03-24-2005).]
                      Hey Carl, thanks for posting these images for us....it's always cool to see this stuff.
                      John
                        The folks over at the metalshapers forum seem to be leaning towards identifying that tool on the column as a Quickwork power hammer.
                        wierdscience, I'm wondering if we are using the same term for different things. A planisher is used to give light blows for smoothing, and not really for doing much shaping like a hammer. Something that you might use for planishing 3/16" thick steel is going to be able to hit hard enough to do a lot of shaping on 16g steel or aluminum.
                        The "power hammers" I've been seeing have been things like Yoders and Pettingells that are used for aviation/autobody sheetmetal, and the "planishers" are things like the CP and homebuilt pneumatic rivet gun tools which work fine for smoothing 16g but don't shape as much or as quickly as a power hammer. If at your shop you were doing a lot of forming of plate and really heavy sheet then something that you used for planishing might well have been what everyone doing lighter gauge work uses as a hammer for forming.
                        http://allshops.org/community/Commun...0187848094.jpg
                        is a CP-style planishing/forming pneumatic hammer
                        http://www.metalshapers.org/tips/fay/page2.htm
                        has photos of Fay Butler with his Yoder power hammer working on .093" copper.
                        cheers,
                        Michael
                          Could the string be from pre saftey glasses days so the workers can find their way to the smoko room at breaks?
                            Michael,the way I learned it to be is both of the items fit in the same category.The one we had would do anything from .006" all the way to .1875" thick.
                            If you look at the picture the bottom anvil is ajustable up and down.Adjusting it up gives more pressure on a hit and down lightens it up a bit.
                            Ours had a 14" radius hammer and a 24" radius anvil,both were about 4" square.
                            I once made a set of niffty stainless baskets for hanging scales out of 22 ga.316,real nice.
                            I did also notice the effect is similar to using an English wheel,the more you strike a location the faster and more radical the forming.
                            It could be a confusion of terms too though.To me a power hammer is a 1500#+ machine for hot forging,but I have heard them called trip hammers,tredle hammers and drop forges,although I think that last one isn't quite right either.
                            Anyway,the one we had was identical in costruction to the one pictured and the factory nameplate said plannisher,It was a Babcock&Hastow if I remember right.
                            American English strikes again
                              Maybe this is what you think of as a power hammer?
                              cheers,
                              Michael
                              [This message has been edited by Michael Moore (edited 03-26-2005).]
