Turning S-7
  • Turning S-7
    Any advise on how to turn S-7? Feed, speed, depth of cut, lubrication? Thanks.
    And.........
    would S5 machine similarly? (No nead to elaborate, don't want to steal the thread)
    Ray...
      I machine S-7 at about 300fpm with carbide and around 75fpm with HSS, maybe a little less depending on the tool. I strongly recommend using the appropriate carbide inserts for this material unless you are just making a few cuts.
      I turn it dry with coated inserts, but use flood coolant if you have it. DOC is determined by available power and machine/setup rigidity. In general you want to give your machine it all it will take, but again, if you are just making a few cuts and production speed doesn’t count, don’t worry about it. Going slow will get you there more surely than “pushing itâ€‌ will.
      Feeds are dictated by many things and the same old rules apply. I suggest you experiment with the parameters and see what yields you the results you want.
