Round square insert (?)
  • Round square insert (?)
    Someone recently told me how he makes his between-centers boring bars. It sounded like a good way to do it, but I can't remember the name he gave to the insert he used. Perhaps someone can help and suggest a source.
    He described it as a sleeve that has a square hole through the middle to accept a cutting tool. He drills a hole in a stout piece of round stock and silver-solders the sleeve in place. Apparently, it also has threads on one end for adjusting the protrusion of the cutting tool.
    Does this description ring a bell with anyone? If so, can anyone suggest a source?
    Thank you.
    Orrin
    So many projects. So little time.
    The operation is called line boring. I have never seen the cutting tool, but I'm sure if you have a bit of ingenuity you can come up with something. Do a search for line boring, and see what you come up with. Good luck.
    Arbo & Thor (The Junkyard Dog)
      Orrin, a while back Vmil3 posted on Cutting Keyways with a shaper. The inserts are described there.
      http://bbs.homeshopmachinist.net//Fo...ML/010643.html
        Orrin,
        Look about halfway down this page, right side. I think this is what you want (Low Carbon Steel Square Hole Tool Bit Sleeves):
        http://www1.mscdirect.com/CGI/NNPDFF?PMPAGE=534
        Barry Milton
        Barry Milton
          I think Reid Tool Supply sells the sleeves, too. www.reidtool.com
          I'd probably install one using Loctite 609.
          [This message has been edited by SGW (edited 03-31-2005).]
            Thank you All for the help. I appreciate it.
            The next time I get a tip from someone I'll write down all the particulars. (But then I'd probably lose the piece of paper. ;-)
            Best regards,
            Orrin
