Screw size/thds question
  • Screw size/thds question
    I was reading an article in one of the "Projects" books and came across a screw size or thrd term that's new to me.
    As an alternative to a 10-32 thead (for a knurled lock nut on a bevel guage) the author suggested a "2BA". I'm familiar with some different thread forms, e.g. Whitworth, acme, square, buttress, etc. and of course metric. But I don't recall ever seeing anything like 2BA. What's that mean?
    Lynn (Huntsville, AL)
    BA stands for British Association and is a commonly used thread by model engineers in the UK and here in Australia. The tread is based on some sort of metric formula and is generally of a finer pitch and more prototypical appearance than some of the others. The 2BA you refer to actually has a major diameter of 3/16"
    you should be able to get some info off Alan Stepney's page;
    http://www.alanstepney.info/
    or let me know if there's anything you need to know.
    Tel
    Tel
      Ok, Thanks Tel.
        Lynn
        They are not 60* threads - BS is 55* and BA is 47-1/2* (I think - check machinerys handbook they may be the other way around)
          2 BA is 31.4 tpi
          Tel
          Tel
