Metal Spinning
  • Metal Spinning
    Not quite so Norm.
    The tame Wolf !
    Enough from you, the Meat Wolf!
    You were kidding us- well, them!
    N
      Metal Spinning
      I am thinking about acquiring a lathe for spinning metal.
      I would recommend any advice you might have in what is available.
      Thanks
      TMT
        From what I can gather most woodworking lathes with a little modification to the tool resst with pins built in should be fine enough perhaps get a book on it.Any metal spinning I have seen is done this way Alistair p.s have much fun
          There was an article or series of articles in either HSM or MW a good while ago about metal spining,one article involved taking apart a 3 in1 lathe and making it into a metal spinning lathe.
          I know the magfazines are around here some where , but probably cant find them with out a seriuos search.
            also an article in MEW from a while back,
              I read somewhere it was hard on a lathes bearings as was knurling with the older style tooling. If that's so, you might want to buy a bigger lathe than planned?
                Y O Dog I don't see how it could be any harder than bowl turning on the bearings but perhaps I am wrong regards Alistair
                  <font face="Verdana, Arial" size="2">Originally posted by Too_Many_Tools:
                  I would APPRECIATE any advice you might have.
                  TMT
                  </font>
                  James P. Riser of Tucson http://www.jamesriser.com/CD_Preview/Intro.html has this web page devoted to his experience in spinning. I recently bought his CD-ROM, but I have not yet had time top view it in depth.
                  Allan
                  Allan Ostling
                  Phoenix, Arizona
                    Nice metal spinning read..JRouche
                    http://prl.stanford.edu/documents/pdf/spinning.pdf
                      Geez , just last night on "how its made" they had a spinning show.
                      The tame Wolf !
                        There are two metal spinning forums (fora) on Yahoo.
                        Metal spinning:
                        http://finance.groups.yahoo.com/grou...?yguid=5735230
                        The Art of Metal Spinning:
                        Paul Wiley is the man behind "The Art..." forum. He is a professional spinner who has written a book on the topic.
                        The other forum has gone somewhat inactive because the leader currently doesn't have the time to participate. Still, the back messages are available and informative; and, the leader of the forum has produced a CD showing spinning techniques.
                        Regards,
                        Orrin
                        So many projects. So little time.
                          The "Art of Metal Spinning" and this board:
                          http://metalspinningworkshop.com/ (discussion board is on lower left) are the two main boards I know about. The Workshop board replaced the Yahoo board moderated by Tynan. Both Paul Wiley and Terry Tynan are professional metal spinners and know their stuff.
                          I also bought the Riser CD, and found later that many of his methods are not considered proper or, more importantly, safe in many cases. I have Wiley's book and Tynan's DVD and from studies of all three, I would conclude the opinions expressed online concerning the Riser CD are with-in reason, especially when techniques are compared one to one.
                          If you read through the forums, there is a good amount of discussion on converting wood lathes (cheaper) and metal lathes (more durable) to spinning. Also, there is guidance on how to make the spinning tools.
                          I picked up a little 12" spinning lathe locally, though I haven't had time to really try it out.
                          Hope this helps, Wes
                            "Spinning" is not that hard, but it is an operation and a technique that no one can put in writing. Start out with a small piece of aluminum and try it.Try to find an Artisan of Spinning in your area.
                            BFH
                              I can't believe you have been a member for 3 yrs. and still asking about metal spinning. Can you no longer read or search for a written answer? Sometimes you have to put forth a reasonable effort to research something; or are you asking questions just to keep a thread going???????????????
                              BFH
