electrical diagram
  • electrical diagram
    Hello All!...I just bought a Rathbone lathe
    and would like to find any info/advice for
    electrical panel. It started out all ugly green paint two days ago!!! Thank you very much...Dean
    [This message has been edited by dneufell (edited 04-16-2005).]
    www.neufellmachining.com
    Advice about what regarding the panel?
    BTW, that is an odd-looking machine. Looks more like some form of special-purpose turret lathe than a general purpose engine lathe.
    Even looks like it has a side tool holder mounted next to the spindle end.
    That big dial is unusual also.
      <font face="Verdana, Arial" size="2">Originally posted by J Tiers:
      </font>
      That's because it's in braille.
        Odd looking??? It has a Hardinge 8 station
        turret on top. A Hardinge cut off tool bolted to the spindle. Variable spindle speed and manual/power feed for both axis.
        x axis has super fine dial (tenths). 8 position stops on both axis. auto coolant.
        very cool looking!(once we paint it)...Dean
          Is that the one in Mass. on Ebay that went for a song? If it is ,Cool,I was eyeing it myself.
          [This message has been edited by lklb (edited 04-17-2005).]
            Nice find. I think that you will like that cutoff tool that is mounted on the headstock. We have them at work and they are handy for barstock jobs.
            rock-
              Hi All! Iklb..I bought it in Mass. but not off e-Bay Rockrat...How do you get the cutoff tool off? We removed 2 small bolts
              and there is 3 dowel pins(all on the face). I do not want to bang on it too hard....Dean
                Yes I said odd looking, and meant it. I don't know Rathbone from Cromarty.
                So what is it about the electrical panel?
                  Hi j tiers...I would like to find a diagram
                  or some info incase i need it someday!
                  [This message has been edited by dneufell (edited 04-17-2005).]
                    Ok...if the neckbone's connected to the headbone...what the heck is the rathbone connected to?
                    Probably going to be a pretty quick machine to use once you get used to it.
                    Nice find!
                    Russ
