A eat trick and a freebee
  • A eat trick and a freebee
    I replaced the shocks in my girlfriend's Toyota Rav-4. Well i read somewhere they make great tailstock alingment tools. They are center drilled on both ends and are ground perfectley round.
    The freebee! I have two of them and i only need one. If someone wants the other one i would be happy to send it.
    Rob
    I'll take it, What do you want for it?
    mark costello-Low speed steel
      Just send me your snail mail address and i will send it!
      Rob
        Hope you dont mind me saying...
        wouldnt worn shocks ....be sort of worn and not perfectly round.
        how about a picture.
        all the best.mark
          Mark,
          That is a realy good point, however most of the time it is the gas or seals that breakdown. She had oil shocks so the seals gave away and were causing no restrcition. There was also a bumper on the shock so it never bottomed out.
          With gas shocks, the gas usualy escapes into the air leaving nothing in the chamber to cause restriction.
          I will take some pictures later on to show you what i mean.
          Rob
            yep when i said take a pic
            I ment show them in use on the lathe
            i'll take your word for it that there is no wear
            all the best.mark
