The ordeal is over, and again I wish I had taken pictures. This move was about coordinating forklifts on both ends, and everything just happened to work out just fine. The best part about this move today was the trailer. I was able to rent a hydraulic trailer that was 7000lb capacity. The platform was big enough for a car and with big solid "D" rings to bind the chains to. The platform lowers to the ground and the ramp was about 2.5'long and with a very shallow angle, which turned out to be great getting on and off. The bed was probably only two inches above the ground when lowered. Even lifting the mill on the forks from the bottom, the forklift had no difficulty with driving onto and off of the trailer with the mill. It was the best $60 I ever spent. I'll take a picture of the trailer because it was pretty cool and it carried the mill very low and very well.
I feel like a big weight has been lifted from my shoulders.
One thought that I had today was to install a 5/8" bolt in each of the holes in the mill's base. I'd leave an inch of thread and the purpose would be so that the bolt would be available to bolt on some square tube for lifting and to make a wide base so the mill couldn't tip over. It’s just an idea and it might end up a nuisance to have those bolts sticking up. And on my mill the control cabinets might be a problem. I don't know how strong the casting is around those holes in the base either. It is just a nerve-wracking thing to move these mills. I'm getting better each time though.
Spence
Spence
