Paint for South Bend Lathe
  • Paint for South Bend Lathe
    Am refurbushing a 10" heavy South Bend lathe. What is the best kind of paint to use: enamel or lacquer? And...what is the proper color? LeBond does not carry paint any more. Has there been a thread on this topic? Any pointers on preparation are welcome.
    Roger
    I've used Rust-Oleum enamel with good results. The stuff brushes on well and is fairly durable. I think their gray is a pretty decent color for machine tools, although it doesn't exactly match the South Bend gray.
    Their have been various threads in the past on painting machine tools, so a search of the archive would probably be of use.
      See here:
      http://bbs.homeshopmachinist.net//Fo...ML/000313.html
      [This message has been edited by ERBenoit (edited 04-21-2005).]
        Matching the original color on a SB can be tough, because the color varied over the years. My 9C looks like it was originally blue. Parts I'm getting from Ebay are different colors. Dark gray, dark gray with a hint of olive drab, light gray with a hint of light green. I'm basing this on what I find to be the color next to the iron as I scrape down. Unless you're doing a museum quality restoration, go with what you like.
          For sure not this color
          This is closer
          This is about perfect IMO
          Barry Milton
          Barry Milton
