? on bearings in elec motor
  • ? on bearings in elec motor
    Among the specs for a 1/2 HP motor are ball bearings, DE bearing:none, OPE bearing:none.
    What the heck are DE and OPE bearings??
    DE is for "Driven End", that's the end with the output shaft.
    OPE is for "Opposite Pulley" end, and that's for the other end of the motor.
      So---that motor has no bearings?
        <font face="Verdana, Arial" size="2">Originally posted by darryl:
        So---that motor has no bearings?</font>
        Not "Ball Bearings". It probably uses bushings.
          Hi There,
          I think the "correct" term is Sleeve Bearings.
          -Blue Chips-
          Webb
            It may have bronze bushings, cheap and easy to replace.
            John
              Some of the older motors have a bronze bushing spherical bearing on the back side (OPE). These are non-serviceable and non-replaceable, as far as I can tell. You can add a few drops of oil to the felt wick that surrounds the bushing but there is nothing more you can do.
              I'll rephrase that -- if you try to do more, like drive out or press out the spherical bearing it will shatter. If you know where replacements can be obtained, let me know.
              Barry Milton
              Barry Milton
                Thanx 4 the replies.
                If you're interested here's the link; scroll down to the bottom.
                http://www.marathonelectric.com/moto...sp?PARTID=Y360
