You'll need a hole that is somewhat undersized to start the boring bar. Since you want to finish at 0.3937" , a 5/16" or 11/32" drill will make a pilot hole with enough left to bore to size.
A hex or square collet block is one way to fixture for drilling & boring. It gives the collet head good support.
If you have a collet chuck in the lathe that is the easiest & best way to drill & bore. The emergency collets are dead soft and machine easily with HSS or carbide tooling. The slots shouldn't cause a problem.
