Hey Fella's
Heres a bunch of questions.
cemented carbide lathe tools:
on I guess lower quality tool bits ( new )
they appear to cut fine but I still have to finish the surface with emery or the like.
looking at the surface with a low power microscope.
you can deffinately see the grind pattern.
would there be an advantage to polishing the cutting surface?
Are carbide ment to be really sharp?
edges?
does it matter?
is the only thing to polish carbide, diamond?
or can you use like mold honning stones?
I am working with 316 stainless right now and was wondering if I would gain anything by polishing the carbide surface.
cutting back on the finishing would deffinately save time.
Thanks to all.
JRW
In the near future when affordable i will install coolant on the lathe, So as you can see this is machined dry.
edges?
does it matter?
Thanks to all.
JRW
