Clausing 8530 Weight?
  • Clausing 8530 Weight?
    Does anyone know the weight of the Clausing 8530 mill? Thanks in advance.
    Are you also a poster at azbilliards?
    \"yes it can be done\"
      The 8520 is around 650-700 lbs so the 8530 is probably around 700-750 lbs.
      Mike Henry near Chicago
        It's relatively easy to disassemble into manageable pieces, too.
