End mill sharpening
  • End mill sharpening
    Picked a a few end mills during a dumpster diving expedition. Unfortunately most of the end mills needed to be in the dumpster. Maybe two or three might be usable as is. Anyway, while looking them over, I decided to try my hand at sharpening the flutes by hand, since they were trashed anyway. Broken flutes, big chips and so on.
    I tried one "technique", laying the end mill on a diamond lap and scrubbing it back and forth while rotating the mill. I did a few strokes and then looked at the flutes with a mag. glass and noted that the original angle had been mostly ground away. Tried the mill with my thumb, felt kinda of sharp but not like a real end mill.
    Question. Does anybody think the mill will cut? I won't get a chance to try cutting with it till this weekend.
    Second question. Has anybody heard of, or invented a way to sharpen end mill flutes by hand with a fixture of some kind?
    I have a fixture that allows me some success in sharpening the end of an end mill on a surface grinder. But nothing for the flutes. Someday I hope to find a used cutter grinder and learn how to use it the proper way. Hard to find.
    In the meantime let the flames begin!!
    Thanks
    A cnc unimat with dremel tool mounted on carriage.
    A digitizing probe to read flutes, angle, store to simple vb program. That is how you'd be cheapest to build a rig to sharpen them.
    I have not gotten the unimat yet.
      You need to maintain the angles. Rotating it on the stone will leave the cutting edges parallel to the work, hence rubbing instead of cutting.
