Contact area check for tapered shaft/ hubs
  • Contact area check for tapered shaft/ hubs
    Where I can find a detailed procedure for carrying out a contact area check using machinist "blue" for tapered steel shafts (Approx 3" nominal diameter) and matching iron hubs.
    Taper is 3/4" per foot on diameter.
    I do not have taper gauges so contact will be between the respective hub and shaft.
    How is the percentage of contact area determined?
    Thank you as always,
    Gearbox9
    Not sure if there is a standard method,but the method I use is to blue the shaft and slide the hub on,then twist the hub 5* and back 5*.Remove the hub and see where the bright spots are on the shaft.
    Idealy you want a contact area of 2/3 starting at each end of the taper and extending to the center yielding a slight hour glass shape.The opposite of that is is a barrel shape and undesirable.
    I quit using Dykem for checking tapers,the stuff I can get locally is a little too thick and it "drags" marring the contact pattern.I now use the common black marks-a-lot,I find it gets me closer to fit faster and it's cheap.
    What are you fitting,prop shafts?
    [This message has been edited by wierdscience (edited 06-09-2005).]
      I'm working on an old Cummins engine with a tapered crankshaft nose. The service manual says to lap the hub to the crank with 280 grit lapping compound. Clean throughly and blue. Place hub on crank and turn 1/8 turn and pull straight off. First 1/2 inch on large diameter should be 100% contact, remaining surface should be 70% to 100% contact.
      THAT OLD GANG 'O MINE
