What makes Loctite "kick"?
  • What makes Loctite "kick"?
    I installed a couple of small Heli-Coils using red loctite. Usually I let this stuff set overnight by the furnace before assmebling, so anything that has squeezed through the coils doesn't also glue the screw in.
    However, after a day and a half this stuff is still very much liquid, and I need to get it assembled, boxed and shipped. What makes Loctite set up?
    Doc.
    Absence of air. It's anaerobic.
    It also has something to do with interacting with the metal surface, since Loctite does sell a surface primer, and the stuff works better with some metals than others.
      Loctite is anaerobic; it cures in the absence of oxygen. They sell an activator, but I have never had to use it.
      Here is some interesting information:
      Click Here
      I can't get the link to take. What did I do wrong?
      Whoops, Steve beat me to it.
      [This message has been edited by Joel (edited 06-20-2005).]
        DP
          If the parts are other than steel or cast iron you will need activator.Sometimes Zylene or acteone works,but the spray activator is best.
            I thought that too but it works on stainless. I did a job where I used it on SS. (316)
            Rob
              DDP
              [This message has been edited by wierdscience (edited 06-20-2005).]
                http://www.loctite.com/int_henkel/lo...9%26layout%3D1
                  I have also found that if there is ANY trace of oils on either part the Loc-tite will not or be very slow to cure.
                    If you're loctiteing brass or bronze bushes into steel,best to get it right first time because it sets nearly as quick as super glue.
                    Must be a reaction with the brass.
                    Allan
                      Hi,
                      Dial 1-800-loctite, ask for tech support. You will get a the info you need from the people that mfg it. Best info you can get.
                      Yours, Jim
