In Australia - Need a gear cut - Can you help?
  • #16
    On reflection, Martin Cleeve writing in Model Engineer in the 50's described how he added stuff to his Myford ML2-4.
    Just at the end of his life, he wrote " Screwcutting in the Lathe"in thw Workshop Practice series. " Your apron is shown on page 17.
    Again, In those earlier articles he did up an apron amongst other rthings like a skew tail stock, steadies,headstock bushes and so on.
    There is a MyMyford group but also an index in Iamnota home page.
    Worth a look
    __________________________________________________ __________________________________________________ __--
    This is duplication which will not "delete"
    Norman
    • #17
      Sorry folks,
      Guilty of repetition.
      Bloody machine will not "delete"
      Maybe the Iamnota link will give our friend some help.
      Cheers
      Norm
      If the damned thing will not budge- may I be positive?
      Model Engineer Vol 113 No 2848 page 943 gives details of some of ML4 improvements.
      Going backwards in the same volume he builds a quick change gear box to do- gear cutting
      • #18
        Nev, There is a fellow in Melb who does water cutting of steel etc. From what I have seen of his work he should be able to cut the gear without too much trouble. It certainly would be a lot cheaper than having the gear cut by one of the engineering firms that cut gears. Pls contact me for more info.
        [email protected]
        John Buckley
        • #19
          Originally posted by NiftyNev
          Finally found a source for the gear. I purchased a piece of gear stock from - http://www.smallparts.com.au/products_index.html - today here in Australia. Heard about them a while ago and only just got around to paying them a visit. They have a lot of cool stuff.
          Nev
          They're a good mob to deal with Nifty, as you've probably found out by now. Also have a forum, pretty quiet, at
          http://www.smallparts.com.au/phpBB/index.php
          & g'day John B - din't know you hung out here
          Tel
