I need to bore and sleeve the hub on the two step pulley from the countershaft of my Craftsman 12x36 lathe. I can get it in the four-jaw, but I am not sure what surface to indicate from to make sure the bore will be be concentric to the pulley grooves. I guess ideally I would indicate off the inside v surface, but how?
Second question: what is the angle formed by the V? I may be able to get set up to recut the V to make sure it is true to the bore, but it is going to be awful close whether or not the cross-slide will come out that far.
Thanks,
Greg
[This message has been edited by gzig5 (edited 06-27-2005).]
Thanks,
Greg
