In using a minimill I have used 1/2 inch cutters(2 flute and more) and 1/4 inch both flute types. With variable speed I generally adjust to what seems comfortable.
I wonder what gives me the better finish the little cutter doing twice as many passes or the bigger cutter doing one pass and a finishing cut at the same depth.
Time is not a problem to this old codger but it seems to me that the smaller cutter has the better finish.
I would be grateful if someone with proper training and experience could talk on this and related points.
Thank you,
bobby.
Thank you,
bobby.
