ANYONE got one of these....J&L code IFX-35004B
and what views do you have on it
its for using with a surface grinder for sharpaning endmills.
http://www.jlindustrial.com/catalog/...id=IFX-35004B#
Additional Product Info
No need to send tools for sharpening; this one unit can handle the complete sharpening needs of most shops. Sharpens saws, end mills - both single and double end, inserted blade cutters, plus much more. This unit can be set up on existing machines at much lower cost than a tool grinder and sharpener. Included in the price are all attachments, manufacturer's guarantee, and all accessories such as spindles, bushings, etc. Extra spindles and bushings are included for pre-setting tools if desired. The sharpening unit will accept cutters with diameters up to 12" and even larger with the use of “Riser Blocks.†Quickly set up, the unit can be mastered in minutes, and any
inexperienced person can become an expert.
all the best.mark
all the best.mark
