Hello All,
It looks like the planned release of our next engine project at the August 13-14 Iron Fever Expo is not happening.
In early May, we released an ad for the July-August issue of HSM stating that we would have the plans and instructions ready for release at the show. (See page 75, top-right corner) At that time, all was well and on track. Since then, we have had several setbacks, the largest of which was trashing the crankcase about 2/3 the way through machining it. (This alone took almost a month of evenings to re-do.) A psychotic pace at work and a growing honey-do list are also big factors.
The LME-125 "Puck" will need to be pushed back at least until late fall to ensure a well-running, durable engine an accurate drawing set and complete instructions. I would rather be sure everything is right before having others pay for a drawing set and be disappointed.
Puck's specs are as follows:
Configuration: single-cylinder flat-head four-stroke
Displacement: 0.27ci
Bore x Stroke: 0.680" x 0.750"
Compression Ratio: 9:1
Weight Goal: <10 oz w/ muffler
Power Goal: Run an 8x6 prop at 10k+
Joy and I will still be setting up at the show, selling our Handy Little Lathe Charts and plans sets for our Pip 3-cylinder radial engine project. We plan to bring the Puck engine and a draft plans set as well. If you can make it to the show, stop by our booth and say "Hi".
Sincerly,
Todd.
Todd Snouffer
Littlelocos Model Engineering
Sincerly,
Todd.
Todd Snouffer
