Hi folks,
I've always wondered how a "best-quality" air compressor compared to my 3hp, 20gal. Craftsman.
The plant I work in is shut-down for inventory. During this time, many large repair jobs can be done without interupting production. The big air compressors are having maintenence done. The crew I work with are rebuilding the gearbox of a BIG stamping press. The company rented a really nice Quincy compressor to provide air to our job. 15hp, 120gal., and the biggest piston compressor I've ever seen on a tank that size. It's about 4' tall, 2' wide. intercooler, aftercooler, unloader, pressurised oiling, spin-on filter, auto drain ect... Loaded.
Anyway, I was using a 1/4" die-grinder, the tank had 125psi and the supply-line had 90psi. I could only run the grinder for 3.5 minutes before the compressor would cycle. It only took 33 seconds for it to recharge.
I kinda thought a tank that big might last longer. My little Craftsman runs nearly the entire time I'm using a grinder.
Steve in Indy
