Now, I am a TOTAL welding newbie... total. I want to weld some thin-wall 4130 tube (say, 1/16th to 1/8th max wall thickness), and occasionally something thicker, like say 1/4" steel plate. I don't plan on welding aluminum - I'll bolt that instead, or mill out of a solid block. This will not be in a production environment, and I will want to take breaks periodically (they are short welds, punctuated by me looking at it, and getting the next section of tube in place), so a 25 or 30 percent duity cycle is OK with me. The tube will be from 1/2 to 1 1/2 inches square stock, with occasional round sections in that size range also.
Yeah, yeah, I know, I would like a nice $1200+ Hobart (or Miller, or...) but...
But, just how bad is this? Is it likely to blow a diode? or a transformer? Or will it just not make good welds? Or is it the wrong kind for the task? Or do you folks think it will work OK for me? Or not?
http://www.harborfreight.com/cpi/cta...emnumber=44568
So, what to you folks think?
