what projects are you working on ?
  • #16
    Scott:
    Does the machine have a separate scale to measure position or does it use an encoder/resolver? If it uses encoders check that the couplings are secure and while you are at it check that any coupling to the lead screw and motor are not loose. These kind of faults may cause the problems that you see.
    Bill
