Asbestos gasket replacement
  • Asbestos gasket replacement
    I'm finally getting around to finishing up a Stirling engine fan called the Moryia. The prints I have call for a thick asbestos gasket between the hot cap and the cold cap. Can anyone suggest a good source for an alternative material?
    If seen reference made to Fiberfrax but am having difficulty locating a source for small amounts. TIA, Jay
    check out high pressure gasket material at your local plumbing supply.
      How about some compressed fiberglass? Might that work?
        Jay:
        The material I used is called "Mr Gasket".
        It is a high-performance gasket material available at some auto supplies, or from a hi-performance race car parts supplier. It looks like thick cardboard, and is the same stuff Jerry Howell sells in some of his kits.
        Ken aka Ozarks Hermit
        Shell Knob, Mo
          Try the Small Parts catalog http://www.smallparts.com/
          Also McMaster-Carr http://www.mcmaster.com/
