I have cleaned a lot of steel with phosphoric. Mild steel, hardened steel, HSS, you name it. Probably have cleaned several hundred pieces, including hardened cutters, ordinary steel, tools, etc. (I have tried electrolytic, uniformly got bad results, de-rusted, but often pitted and always covered with black gook).
Every time with phosphoric, I have either suceeded in cleaning all or most of the corrosion. I have never had any sort of attack on the steel.
The last time, I had some hardened steel pins with some rust , so I did the usual.
This time, the steel was actually eaten severely, with a network of "martian canals" eaten into the surface. Easily felt with a fingernail, easily seen, probably 0.005+ deep. Pins were totally ruined, they aren't even scrap now, because they were hardened, and would need drawn to even re-work.
Has never happened before. I have left steel in for a day, and had NO progression of any sort of attack on the steel.
I know the rust wasn't at fault. The rust was all on one side, but the "canals" were all over the pieces.
All the pins are known to be of similar/same composition, and in any case, they were not touching each other. I always avoid that for exactly this reason.
Any chemical reason for this?
Best I can figure is local electrolytic action if the steel composition and hardness was not uniform. It may not have been.
I think the pins may have been case hardened, and the "canals" are in a pattern very similar to the mottling on those "color case hardened" tools. That suggests a variation in composition, and resulting difference in local potential.
